Little confused. Do you have the Quad-Rail Enermax 660w you first linked to or the Tri-Rail Antec 650w that you linked to later?
Anyway, I just found your power supply label from the last link you posted....
http://www.ozhardware.com.au/P...ower-Specs-and-Te.html
.....and it appears you have anywhere from 37a to 52a of sustained/continuous amperage on your
combined +12v rails depending on how much wattage is being utilized on your +5v and +3.3v rails. This should be more than enough for your 8800GT as N7 said, unless the power supply is damaged. As far as the 8800GT goes, you only need 22a of sustained/continuous power on the
combined +12v rails for multi-rail units like yours, or 22a on a single +12v rail for a single-rail power supply which yours is not. Your confusion lies in how EVGA for example lists their specs, they just said 22a on the +12v rail and left off the combined rails for multi-rail units part. Also as N7 says, this figure is for total system power, not just for the 8800GT by itself.
Also, as ArchAngel suggested you may also have the firmware issue with your power supply that has affected some 8800GTX users. I have also seen this same issue "appear" to effect some 8800GT users as well so you may want to consider swapping power supplies or puting your card in another system for testing.
