8600GT & Ultra Info UPDATE: 256bit
Cookie Monster
5,161
32
86
Originally posted by: Auric
Bring on the 8600U AGP :)
I wish. I dont think so personally because of NVIDIA's stance toward AGP. While ATi launched several AGP cards e.g X1650pro, X1950pro nVIDIA didnt counter them with any new AGP cards. (They could have with 7950GT AGP for example). I think AGP is nearing its end.
It would be great if it was true though but highly unlikely.
Ateo
33
My Gainward 7800GS (20 pipe 7800GT core) Bliss 512 MB begs to differ.
And the Gainward 7800GS+(24 pipe 7900GT core) Bliss 512 MB protests loudly ;)
aimforsilence
123
AWESOME!!!! The GeForce 8600 Ultra is what ive been waiting for... it'll be a wonderful upgrade from my 7600 GT when it's released soon (hopefully)
nitromullet
9,031
36
Originally posted by: A554SS1N
The Ultra branding went ages ago, for this reason I think this is all just a collection of made up thoughts and rumours.
The GTS branding also went away a long time ago, yet NV launched the 8800GTS just a few months ago. So, I wouldn't cast this off as made up soley based on that.
Shamrock
1,441
566
Don't count out the fact, that BFG10K has said numerous times, that the 88x series has FIXED the shimmering, and that the IQ is supurb to the 79x series. That alone is enough for me to upgrade to this, I can handle $179...not $529
If the 8600Ultra is faster than my 7900GT WITH superb IQ, I will gladly lay down $179
Cookie Monster
5,161
32
86
That aint an offical SKU from NVIDIA though ;)
DeathReborn
2,770
775
It may not be official but it uses the nVidia Bridge Chips & standard GPU's, just not how nVidia expected them to be used.
The 8600U 512MB should be on a par with a 7900GTX, possibly more with a healthy OC. These are based on 80nm so should be able to hit 650/700MHz on the core.
Auric
9,591
Difference is the 1650 and 1950 are reference designs by ATI which any AIB can simply duplicate. Even the 7600GT is not that, apparently, and so even though it is very similar to the general design of the 6600 (and indeed the 7600GS) all but two AIB's couldn't be arsed. Likewise, the minimal effort made by Gaywad to make their non-standard 7800's meant they remained unique. So, while both ATI and Nvidia say AIB's are free to do as they will with the bridge chips the reality is they largely have not. Now that ATI has stepped up this generation, hopefull Nvidia will do likewise. Nice to see that Powercolor quote: ?We still have a huge demand for high-end AGP?.
blckgrffn
9,293
3,435
www.teamjuchems.com
Good for powercolor. It seems to be an oxymoron to say high end and AGP anymore, since you are stuck with A64x2/FX as your highest speed processor. Core 2 is where its at, and while I think you can get an AGP board for Core 2, why would you work that hard?
On topic, this sounds perfect for my dad. He can live on the x800xt for a little while longer...
BernardP
1,315
More news on Anandtech main site, along with other DX10 info
The title doesn't always say it all
NVIDIA has two G80 derivatives designed to target the more mainstream segments: G84 and G86. G84 will be the base of NVIDIA's GeForce 8600 while G86 will be used in what is currently known as the GeForce 8500. Detailed specifications aren't known other than the chips are supposed to be 80nm, but expected launch date is around April or May.
Cookie Monster
5,161
32
86
Link
According to VR-Zone, the rumours that the GeForce 8600 (G84) will be using a 256-bit bus are incorrect; instead the chip will still be using a 128-bit bus, like its mid-range predecessor (G73), a configuration which matches what we have heard. They further claim there will be two versions upon initial release; one at 650/900, and the other at 550/700, both with 64 shader processors.
Assuming the architecture did not change, this would imply 16 samplers and 32 filtering units, and the equivalent of 8 ROPs (but with "free" 4x MSAA in terms of depth tests). Practically, this is rather similar to the figures of the Radeon X1950 XTX (higher in terms of filtering; lower in terms of ROPs, arguably), but this card would have less than half the bandwidth of that SKU.
Furthermore, it would be assumed that a mid-range card tends to be used at lower resolutions than a high-end one. As you move up in resolution, the overall bandwidth requirements go up, but not as fast as the fillrate increase because the memory coherence also improves (triangle size goes up, relative texture sizes go down, etc.)
However, G80 has significantly more texture cache than any part that's come before it (128KiB of L2, and a fair bit of L1 too). While an efficient texture cache mechanism and hopefully quite efficient framebuffer compression techniques can't hurt, they are also unlikely to do miracles. That's why we speculated NVIDIA would go with 1.1GHz GDDR4 for the higher-end model, but perhaps the prices on these memory chips are still too high. Either way, it remains to be seen how bandwidth limited G84 will be, should these specifications be accurate.
Something to ponder about.
blckgrffn
9,293
3,435
www.teamjuchems.com
Link
Nice catch. It makes sense though. A 256 bit midrange card might put too much pressure nvidia's cut down "low highend" sku's...
Nat
Yreka
4,084
Nice & Short, no external power connector. I will be saving a spot for one in my HTPC, unless of course they don't have the scaling issues worked out by then.
chizow
9,537
Keep in mind the G80 derivatives will all run different drivers than their 7-series and below brethren. For those of you who are looking to "upgrade" to a mid-range DX10 card that performs more or less the same as your high-end 7-series card, you might want to wait until some DX10 games actually show up or drivers mature a bit. Right now, there's a lot of small problems with the 8800 drivers and the impending launch of Vista will only slow down how quickly they're being fixed.
akshayt
Banned
Feb 13, 2004
2,227
IMO 8600GT will compare with 7900GT/GS 7950GT 1950Pro X1800XT in todays titles.
8600Ultra will compare to 1900XT/XTX 7900GTO/GTX
REMF
141
if the 8600U is a 256bit part with 7900GTx performance I will buy a pair to stick in my short depth HTPC case.
BernardP
1,315
I have been wondering about this. Lots of people will be running these new cards, especially 8600 and 8300 series, on XP machines, without DX10 support. So these cards will be DX9 only with XP.
Looking on the NVidia web site, I can see that there are different "unified" (sic) drivers for the 8800 and 7xxx series. But these are XP drivers only for now.
I would tend to believe (hope...) that XP/DX9 drivers for the 8xxx series would be less problematic than drivers for Vista/DX10.
chizow
9,537
One would hope, but sadly, I don't think that's the case. One of the many, many reviews I read researching the 8800 had a comparison and breakdown of the different drivers nVidia had to deal with in regards to the 8800 launch and the impending Vista launch. Basically, there's going to be four drivers that they need to update and support for some time to come. Each driver is @20 million lines of code, as the review stated, comparable to the amount of code in Windows NT.
1) Unified GeForce for all 7-series and below for XP
2) Unified GeForce for all 7-series and below for Vista
3) 8-series+ for XP
4) 8-series+ for Vista
With the launch of Vista, nVidia is kind of in a pickle trying to ensure as many current titles and future titles are compatible with Vista making 2 and 4 a priority, while trying to fix the bugs in 3 with current titles for a newly launched GPU on an older OS. So you can clearly see, if you're not in a hurry to run DX10 games and Vista with an essentially parallel upgrade in terms of DX9 performance, you might want to wait a bit to jump on the G8X bandwagon. Even though I feel the 8800 series XP drivers are pretty polished for a new GPU, there's still plenty of problems (check the release notes) in popular titles and that's before mentioning any of the problems with the very unpolished SLI features.
SolMiester
5,330
17
Originally posted by: Eomer of Aldburg
The 8600 Ultra looks very enticing, especially for the money and dx10 support. Hopefully it comes out in a few months! Will be like night and day from my 6800GT.
LOL, imagine the diff from a 6600GT to 8600GT...ohhh
