8500 shows flickering when scrolling-vid card problem?
blackhawk
2,690
When scrolling or in a light coloured screen, my display shows vertical dark banding moving from top to bottom. Sometimes more apparent than others. I run XP and default settings on the vid card. I used to think it was the monitor but did a swap this weekend to check and its in the card. It still has the retail bios and tried several different drivers over the last couple months.
I did a search at a couple sites and didn't see any consistant complaints about this so wondering if any other suggestions.
I checked the ATI site and will email their support next.
ScrewFace
Banned
Sep 21, 2002
3,812
Let us know how you make out with ATI's E-mail support. I found that sometimes they answer you back and sometimes they don't.:)
blackhawk
2,690
quick but lame response from ATI, basically linked me to all kinds of info about different ATI products than the kind I specifically emailed about
told me to update drivers for every device & system on the mb!!
not real impressed with that answer so I swapped the vid card to an older BX system where the problem persisted so I emailed again
two days later I was told to fill out an rma form---odd thing, just built up a new system with Epox 8k9a2+ & an amd 2400XP and put the radeon in it, no banding!!!
I've no idea how I cured it but cured so far--pretty good response from ATI as far as I'm concerned, I could spend a couple bucks and rma it but wont
rogue1979
3,062
I have noticed similar behavoir with different 8500's and 9500'a. On a light background scrolling can cause a momentary shimmering of light and dark colored bands, almost like a slow refresh rate. It only lasts for a second or two, and it is hard to notice sometimes.
