With two hot computer buzzing away loudly under my desk, I am looking for some kind of solution for quiet without risk of overheating:
All thing being equal, the larger the fan, the more air it moves. So rather than take the already warm air in the case and shoot it through a whining 7k rpm 60mm fan, why not use a good heatsink (like the GW32/38) and a larger quieter fan to move cooler air from outside the case through a duct?
The rear case fan hole on nearly every case I've seen is designed to fit a 80mm fan, and it is only 6"-8" away from the top of any heatsink mounted on a socket CPU. All you'd need is some kind of flexible tubing and an interface for the heatsink (like the 60mm to 80mm adapters people are talking about on this forum).
The vaunted (screaming) Delta fan is only rated for 37cfm and is LOUD at 46dBA! Someone else mentioned Mechatronics (http://www.mechatronicsinc.com/products.htm) -- they have an 80mm fan that will do 46cfm at only 32dBA!(model F8025E)
Anyone try this before??
