kamranziadar
Banned
Can i put 80mm cas fan on the cpu for cooling instead of regular cpu cooling fan. For AMD 64BIT 3200+
That's an interesting question. I guess it depends on how big the heatsink is. For the amd64, the heatsink is fairly large so I think the 80mm would be better.Originally posted by: kamranziadar
Is it better than a Stock Fan.
I tried to put 80mm on the heat sink and it fits like it is made for it. but when i check the air flow of stock fan it looks just as good as 80mm. I think i should try it for a while.
Any body know any good fan with good price
Originally posted by: KalGor
I know this is a stupid question, but ive never used any CPU fan other than stock.
Which pin connection do you need to use a fan as cpu fan? 2/3 or 4?
Thinking of using Panaflo 120mm M1A Fan 86cfm 35dB(A) - Fluid Bearing, with the Thermalright XP-120
Good or bad decision?
Im not planning on OC from the off, but will be at some point down the line, so im A) makin sure i hav the cooling there ready, and B) I can benefit from the cooling in the mean time?
I'm thinking you'll need the 3 pin connector cuz that's what connector a mobo has. Generally, your mobo needs to monitor the cpu fan or overheat protection will kick in and she'll shut down.
Ok so this fan should fit no probs, so long as i get the 2/3 connector? Nice. thanks. 🙂
