80mm Nexus Fan
forumposter32
Banned
May 23, 2005
643
LOL, isn't that just the thickness of it?
Try it, if it doesn't fit, try longer screws from a hardware store. Is it that much more complicated?
Eltano1
1,897
Exctly, 25 mm is the thickness of the fan, follow what forumposter said and you will be OK.
Eltano
FlyingPenguin
1,793
Yes it is the thinkness. Should be no problem if it's just mounting to the case with screws.
Nexus fans are EXTREMELY quiet. I use them in my Media Center PCs.
