Has anyone zip tied a 80mm fan on their pci slots of their case? How well will this work? I have a 8800gts that has a WHOLE LOT of hot air venting to the bottom of the case just waiting to be vented. Its so warm in there, I just need a solution.
UPDATE: Here are the pics of my modded case with the two fans I placed. The side 120 is only zip tied on the bottom two holes, but is very sturdy. The rear 80mm fan is tied in with all 4 holes zipped. There is one extra 80mm fan on the top side vent which cant really be seen, but its there.
side
close up side
close up rear 80mm
side closed
front open
front closed
Pics as I promised
side
close up side
close up rear 80mm
side closed
front open
front closed
Pics as I promised
