- Jun 24, 2004
- 1,695
- 1
- 0
what do you recommend? the rear exhaust in my pc has a ton of wind noise for some reason and the front intake isn't too quite either. thanks.
Originally posted by: Pyrokinetic
The Panaflos are great fans (I have a 120mm one on my XP-120 heatsink) but I am really annoyed that they do not include a fan rpm monitor. Even cheap fans include one, so what is with Panasonic? Because of this issue, I have to plug in one of my Nexus fans to the CPU fan connector on the motherboard and plug the Panaflo into a secondary fan connector or when I boot, I get a CPU fan speed error and have to press F1 to continue. I was not aware of this issue when I ordered it, and I will never order another Panaflo. An rpm monitor should be standard with ANY fan, and Panasonic is stupid not to include it.
As for the 90mm fans on 80mm mounts, that is a great thing, but probably is not what Reck is looking for as a solution as the original problem was "wind noise"; a 90mm fan forcing air through a 80mm hole would probably only aggravate the situation.
