Yes and yes...You can add a different HD but the RAID0 performance (theoretically) plus size will be based off of the slowest HD x2 so matching HD's are preferred and you will have to reformat/stripe both as 1 HD.
You only have to reinstall if you're doing RAID0 (striped array). If you do a mirror array, every RAID device I've seen builds the mirror on the fly after you add the second drive and designate it as part of the array.
