8 pin PSU to 8 pin PCI-E
bharryb
Hi
I bought a thermal take 450W power supply that acts secondary to a primary power supply. Anyway it came with 2 6pin PSU to PCI and 2 8 pin PSU to PCI.
I did not need the 8 pin at the time and so stored them with the box.
I have moved house since then and the box has been lost in the move and now have a new graphics card that requires an 8 pin to plug into the power supply and a PCI-E 8 pin on the other end
A small diagram of what I need.
PCI-E 8 pin (male)-----------------------------------Power supply jack (male)
I see them everywhere when looking at a power supply but can not find them anywhere by themselves.
I have an 8 pin power cable with a 6+2 pciE cable on the end but that does not work :s.
Any advice or any idea where to find them?
Thankyou very much
bharryb
Thanks for the reply. I cant not believe I did not see that, I could not see the store section of their website!
My original product is this.
http://www.thermaltakeusa.com/Product.aspx?C=1265&ID=1543
However the cables in the store dont have an 8pin to 8 pin, only 8(6+2), which I have tried and don't work :(.
Also even those cables in the store say ''only valid with etc product'' Or will it work fine with my model do you think?
