- Aug 27, 2001
- 6,770
- 1
- 81
The 8 pin CPU power connector on my Enermax 720w is barely long enough to reach the motherboard connection. It's so tight that I can barely fit my GPU and can't fit my sound card (the psu is on the bottom of the case). Are there 8 pin extensions I can buy and use or can I just go with a molex to CPU power adapter? I would rather use an extension but at this point I just want to get my X-fi back in there.
Thanks!
Thanks!
