7volt trick does size of fan matter
lapdog
248
7voly trick does size of fan matter i as because i tried it on 2x sunon fans first the quit 35.5 dba and next the 42 dba fan i then tried it on the fan that comes with the enlite 7237 case and it worked perfect it was a 80mm
BAMAVOO
41
I am using the 7volter on 2 92mm Sunons..2 80mm Antec and 1 80mm Sunon..Work great so far.:D
Thanks joinT
