7v mod on delta anyone help?
SnowPunk98
Banned
Jun 15, 2001
4,933
I have a delta hate the thing I want to use it on 7v cause the fan I have on now isnt cutting it if I run this fan at 7v What kinda CFM and whatnot should I get and hwo do I do it just connect the yellow to the black next to the red?
sohcrates
7,949
To wire it up to run in 7 volt mode, you'd keep the fans positive lead connected to +12 volts (yellow) but you'd connect the fans negative lead to +5 volts (red) instead of the usual ground (black)
this will quiet the fan, but also make it move less CFM
BeauJangles
13,941
I believe you are looking for the 'delta quieting mod' which involves 1. removing the delta from your computer 2. logging on to FS/FT 3. selling it. 4. using the money you just made to buy another fan (nidec, sunon, NMB).
:D Good luck with the 7 volt mod.
BeauJangles
13,941
what heatsink are you using? Have you applied thermal grease properly? How many fans running in your system?
sohcrates
7,949
<< all done still gettin horrid 55 temps >>
ummm...running your fan at 7 volts is NOT going to help temps...it's going to help noise
