7970 Overclocking with voltage control :o)
Arkadrel
3,681
I can't believe they are not holding something back for a new revision once team green launches their cards.
Appopin was the one saying AMD might do a revision before next Nvidia cards...
with this much potential still left on the table, Im starting to think he might be right.
so....
480 --> 580
7970 --> 8970 ? only time will tell.
Dark Shroud
1,576
It will be interesting to see if anyone comes out with an HD7970 prefitted with a water block (various manufacturers did for the GTX580).
Powercolor did that with the 5970 & 6990 so I wouldn't put it past them for the 7970.
Arkadrel
3,681
here:
1 x 7970 overclocked to run @ 1700mhz core, 1980mhz memory:
and:
Arkadrel
3,681
@DarkKnightDude
Nope thats sub-zero overclocking, still... 15k+ 3Dmark11 P score is pretty nuts.
Most people with SLI 590 (2x 590 = 4x 580 gpus) dont even have that.
I know, doesnt matter if not on air/water.... we ll have to wait until people start doing those.
wahdangun
1,007
148
here:
and:
holly cow, wth, wtf o_O. its really impressive.
to be honest i never expect the card to pass 1,3 Ghz, but this 1,7 Ghz on graphic card really mind blowing.
ArchAngel777
5,223
61
A Greek forum member at HardOCP received his Sapphire 7970 and he overclocked it to 1125/1575 out of the box:
http://hardforum.com/showthread.php?t=1662199
He posted a pic of his Sapphire card, it's the reference design with a Sapphire label stuck on it.
Nice will wait a bit to see how others respond... If this true, my guess is AMD will do a respin just as Apop predicted.
The one thing that Kepler does NOT have going for it is predictability. We know that going from 512 to 768 cores is probably going to net a static 50% increase in performance (give or take 5%) and since it is using the same arch, it will be predictable as to what we can expect. That means, if AMD can respin the 7970 into an 8970 in the next three months and clock this monster at 1.2Ghz range, it should compete with Kepler quite easily. It will dominate in some games like Shogun 2, Skyrim, etc.. and be slightly behind on games like BF3 and so on.
These are fun times!
badb0y
4,015
30
I think I am going to watercool this card....those OCs look beastly and it seems like AMD could have upped the stock clocks a little bit.
AnandThenMan
3,979
589
A re-spin is not coming in 3 months. But AMD looks to have clocked the 7970 very conservatively, with process improvements a 1.2Ghz card seems quite plausible. Time table for that, not sure.
BTW, I am using the term "re-spin" to mean a new stepping.
Idontcare
21,110
59
I wonder what kind of power-consumption such an OC'ed beast must pull?
I have to imagine this made a few sphincters pucker a tad over at 2701 San Tomas Expy, lots of potential for AMD to do some extreme clocking SKU's if they need to.
Arkadrel
3,681
According to guru3d's measurement, the power draw under load went from 195 to 229 watts when overclocked to 1125/1575, a 17% increase:
http://www.guru3d.com/article/radeon-hd-7970-overclock-guide/3
^ if it scales by around (229-195) = 34watts pr 200mhz overclock (925->1125mhz), that means the 13xx mhz core cards will use like ~264watts when their running at performance levels of the 6990/590.
Factory overclocked 1350mhz core cards gonna be pretty nuts.
3DVagabond
11,951
204
They'll need more voltage, don't you think?
Grooveriding
9,110
1,260
Yeah for sure. For a card 30% faster than the 7970 already is, could care less myself. 300W is fine by me as long as it is smoking fast and doesn't get obscenely hot or loud in the process.
HurleyBird
2,759
1,455
Where can I download AMD gpu clock tool 10.12.0 that Shamino is using? All I can find is ancient versions that don't work anymore.
Kippa
392
When the reviews first came out for the 7970 they were good but not earth shattering. Do you think the standard clock rate was undervalued conservatiley and was a rush job to get the cards out as soon as possible? Maybe if they had a bit more time the standard values could have been tweaked a little higher. Perhaps this card is better than expected.
3DVagabond
11,951
204
I think clocks are set as high as needed to reach O/C'd 580 plus a bit. Gives them the fastest card and the highest yields. Down the road as the process matures they can increase clocks. nVidia did the same thing with the 460 (likely for different reasons). Conservative clocks to start with, down the road we have the 560.
blackened23
8,548
Yep, it sounds like they are indeed doing this. Another rumor indicates that part of the die isn't fully in use yet (GTX 460 was the same way) in order to get it to market faster. I'd be awfully surprised if tahiti pro wasn't refreshed with dramatically higher clock speeds and additional CU's.
Kenmitch
8,505
2,249
Although most people aren't gonna be using LN2 it's nice to see the overclocking potential of GCN.
If yields are good we should see some nice factory overclocked versions if they can manage to keep temps inline.
I'd think that a full water block would tame one of these beasts!
Damn....Too bad they are pricey and I don't have any need for one of them :(
Arkadrel
3,681
@Ken
Sapphire is doing a 1335mhz air cooled version, factory overclocked (thats a 44% increase in clock speed).
And I dont think even factory overclocked cards, will be pushing the headroom avalable, so Im pretty sure buy one of these, you probably be able to push them abit higher on air (say 1400-1500).
Also they ll be faster than the 6990 or 590 is.
