7950 to ???
hyrule4927
359
yacoub
1,991
14
3570K with HD7970 here. Also not sure what to get at this point.
Have two 1920x1200 displays, usually only use one when gaming. May get a third at some point and try triple monitor.
Only play a few games though they include FPS or other things that need some good GPU horsepower.
Was waiting for Fury X but that turned out to be a bit of a letdown. 980Ti seems like overkill and since the Fury X didn't debut at $550, I don't really have interest in stepping up to $650, but I do want some good future-proofing in whatever I do buy.
Planning to replace CPU & Mobo with Skylake or whatever Intel drops this fall, but open to getting the GPU sooner.
raghu78
4,093
1,475
a R9 290 if you can get for USD 250-270 or a R9 390. R9 390 is a good 40% faster than a R9 280X / HD 7970 (1 Ghz).
http://www.computerbase.de/2015-06/amd-radeon-r9-fury-x-test/6/
http://www.computerbase.de/2015-06/amd-radeon-r9-390x-390-380-r7-370-test/3/
AtenRa
14,003
3,361
If you want something at $500-550 wait for a few weeks(should be release in July) for the AirCooled Custom Furys and Fury Nano.
AtenRa
14,003
3,361
The Sapphire Nitro 390 is the same price, though I'm not sure which is better.
I would go for the MSI,
1: Bigger(Taller) custom PCB, better for thermals and power consumption
2: Dual Larger fans vs 3x smaller
3: Back Plate
4: 3 years guaranty vs 2
edit: Also MSI has 3x pre-sets for those that dont manually OC,
(OC 1100MHz/6100MHz, Gaming(Default) at 1080MHz/6000MHz and Silent mode 1050MHz/6000MHz)
hyrule4927
359
3: Back Plate
My only concern with the MSI is that, like my MSI 7950, the VRMs are going to run hot. I was looking around for some reviews of 290, 290x, 390, or 390x with the Twin Frozr and Tri-X coolers, and it looks like the VRM temperatures are closer to 100C with the Twin Frozr and closer to 75C with the Tri-X. Think that is something to be concerned about? Looks like the core also runs about 10C cooler under load on the Tri-X cards.
MSI 390X VRM temperatures: http://www.tomshardware.com/reviews/amd-radeon-r9-390x-r9-380-r7-370,4178-11.html
Sapphire 290X VRM temperatures: http://www.legitreviews.com/asus-r9...re-r9-290x-tri-x-video-card-reviews_132158/11
I realize that isn't a perfect comparison since they aren't both 390s, but it was the closest thing I could find.
yacoub
1,991
14
I would not recommend he buy something with 3.5GB of fullspeed VRAM in an age where 4GB VRAM is already questionable as far as future-proofing goes. I'd much rather recommend something with 8GB VRAM that is pretty much just as fast as a 970 and costs roughly the same.
AtenRa
14,003
3,361
Well i dont believe the MSI R9 390 Gaming has a prob with the vrm temps but i will wait for Toms to review another 390 and compare.
Personally i want to also see the ASUS Strix when it will launch and compare the two.
Kallogan
340
aftermarket r9 290s without the x still are the deal
a gtx 970 is a no brainer too, especially if your psu is not a powerhouse.
as for the rest...meh too expensive...not worth it
