Originally posted by: Doctorweir
Originally posted by: sisq0kidd
I couldn't help it. I ordered 3.
Tri-SLI? 😀
And yes, tell us how many pipes/shaders and if they can be unlocked, as the core is G71 😉
Originally posted by: tuteja1986
I wait for the review before all of you started to buy it and found it be not as good as you may think... i do hope it can beat a 7800GT 🙁
Originally posted by: DAPUNISHER
With a 2.6ghz X2, it should score right around 4500 in 3DM06, damned good for $144 and change to the door :thumbsup:
Well, it technically has to beat a 7800GT. Same pipes, higher clocks on core and much higher on mem. It's a 100% white box special. No cables whatsoever, no CD's and probably no DVI adapters, which means you have to have at least one of your own, and a PCI-e power cable adapter if your PSU doesn't already have one.
I'm running two barely (never) used 7800GT cards in SLI. Would it make sense to sell them and buy these? I know I don't have much time for these questions but I'm broke and if I can make even a little back from the 7800GT cards I need to. 🙂 Judging mby the HSF, I don't see how it can have higher clocks with the same configuration.
http://www.woot.com/
$140!
Way lower price than Nvidia has suggested.
How does this compare to a 7800gt?
Originally posted by: estew33
Hi All,
I have a sort of stupid ?. If you buy two of these cards, will they come with the connector you need to run them in sli.
If not is the connecter able to be bought ,if so is the price reasonable and is it pretty easy to find
thanks for all and any help
Ed
$140!
Hi All,
Ed
It's running on a cooler process than the 7800GT, which is why it can afford tyo have a smaller HSF. It also might be a good idea to sell your SLI setup and buy these. You'd walk away from the deal with some leftover money in your pocket and a 5-10% faster setup that should have a good ability to overclock if you so chose.
I'm extremely tempted to pick one of these up to play with. Heck, if it overclocks half as well as the 7900GT, I might wind up replacing my X1900AIW...that I've only had for two weeks 😛
$140!
Hi All,
Ed
From the specs:
Fragment Pipelines: 20 (24)
Vertex Pipelines: 7 (8)
Texture Units: 20 (24)
Raster Operators: 16
I don't know if its got 24 pipe or not... if it does its an amazing deal. if its just 20 its proabably a bit faster than a 7800GT.
Either way thats pretty good price.
I'm a bit confused by the numbers in the parenthesis. What do they mean?
exactly. Its either 20 pipe card or a 24 pipe card I don't know. Thats how they have it listed.
