Yep, they even have a kit for it: http://www.amazon.com/LEGO-Make-Crea.../dp/B000FIH06OYes, and they used LEGOs to build the fuselage...
I don't recall when they started certifying twin engine jets for ETOPs, specifically trans Pacific flights, but I think it was less than twenty years ago?
It seems strange to allow new planes to fly long distances from any landing field before there has been some amount of history for a brand new plane.
It sounds like they are far too trusting of technology. Especially when we have examples of fires that might doom a plane that was too far from a landing field.
Just my 2 cents but I would like to see them fly 6 months non ETOPS just to work out the bugs.
News like this makes me wonder if our level of technology is getting too complex for us to grasp fully.
Nope, quite a few small pax planes have no APU and need no APU.
Some just have batteries.
Some have a RAT.
Some have a combination. Most big airliners have several ways of getting power.
Some RATS supply electricity, some supply hydraulic pressure, some supply both.
Sometimes a windmilling turbine or prop will provide some power.
Many airliners can't dump fuel, either.
IIRC, the 747's APU can't be started in flight. 4 generators are considered enough redundancy.
Cracked cockpit windows probably happen a dozen times a day on airliners. Cockpit windows are electrically heated on airliners. It's very common for the temperature differences to crack the outer pane.
Oil leaks, too.
Both are very common.
Woah awesome, that looks like a space ship cockpit.
US regulators are taking th problem seriously and have ordered an review. Hopefully they will get to the bottom of this quickly.
http://www.bbc.co.uk/news/business-20988117
It used to be that cockpits looked like this
Now they look like this:
http://www.youtube.com/watch?v=jjb3yeuVNf4
A380 3D cockpit view
787 cockpit
(CNN) -- A Boeing 787 Dreamliner made an emergency landing in Japan early Wednesday morning after an alarm signal on a battery activated, a spokesman for All Nippon Airways said. The incident follows a string of recent mechanical and other problems associated with the 787.
Keep in mind that the RAT is only an emergency system. I also, I find it incredibly difficult to believe that the APU on the 747 cannot be started in flight as it would partially defeat the purpose of having one. Sure, most APUs have on the ground and inflight limitations for starting and operation but to not be able start it in flight is preposterous.
