7800GT Temp issues
RampantAndroid
6,591
I have a VF700 on my 7800GT and I hit 70C while loading using RTHDRIBL....as soon as I pause rthdribl, my temp drops to 60, unpause a second later and the temp jumps to 70C again. This is really wierd...I don't get it. I hit 70C whether my clocks are 445/1070 or 480/1200...this just a driver/bios/hardware problem?
The case I use is a P180, WELL ventilated....room temp is around 25C.
I'm going to emphasize this: as SOON as I pause rthdribl, temps drop within less than a second...then they jump back up once I unpause (again, they jump up in less than a second.)
I'm making a thread for this rather than hijaking someone else's thread....
RampantAndroid
6,591
I had reseated....made sure there was enough....I'm pretty sure there's enough pressure too (went as tight as I could). That's why I making this post, I thought that'd fix my problem.
TheRyuu
5,479
14
Bad temp monitoring?
What thermal compound? How much you using? (as in are you using too much)? You sure you installed the VF-700 right?
If you do take apart your VF-700, those thumb screws on the top and the bottom, make sure they are tightend really tight too, maby thats causing you to not have enought pressure?
(after that I really wouldn't have a clue :p)
RampantAndroid
6,591
Not too little, maybe a little too much, but that's never cause me problems before. I use AS5, though I am seeing that ceramique is better, so I may get some of that.
I'll shut down my computer after I post this and check it all again, including the pressure on it...BUT...before I do, I have some pics you'll want to see:
Pic 1
pic2
-I left the time on the bottom so you could see this isn't changing.
Now, this is 15 minutes AFTER I played HL2. I touched the heatsink, and it isn't that hot. My card is saying that its idling at 57C?!?! Not a chance in hell, it idled at 43C until just now...WTF! I'm calling up eVGA methinks...RMA time??? What does everyone think???
