7800GT idling at 50C
BFG10K
22,709
3,002
I think he means his ambient case temperature, not his room temperature.
Noid
2,390
193
My abient temp for my rig in sig is ....
29-30C
measured in middle of case above the NB, it's hotter at the top near the PS obviously.
CPU at 1.85v is 48C during surfing.
Abient room temp 22C.
All temps at web surfing ... (as I type this)
I'd say his case needs some better organization to reduce temp.
Feb 19, 2001
20,155
23
Originally posted by: DLeRium
fvck just read this thread and checked my idle temp.. 69
then i noticed all my fans are off.. WTF?!??!?!?!
GOod god. My CPU was running 38 idle. Restarted and the fans powered on...
CPU idle 30, GPU idle 46.. more like it...
TheRyuu
5,479
14
Lets see, both my 7800GT's have VF-700's on them Temps:
GPU1: 55 idle
GPU2: 50 idle
GPU 1 (first 7800GT) is so hot because for starters my extra case fans havn't come yet and the stock ones with my case don't move jack (30cfm at most). And second, there is a X-fi Sound Card squeezed between the two video cards, which make temps high on the first one cause it's restricking air flow (sort of). I'm thinking of putting a 120mm fan infront of the 7800GT's to blow on them to "just get the air moving" down there since those 80mm fans don't move jack air either. Think it's a good idea? Just wondering?
Lonyo
21,938
Mine runs about 55 or just under, but that's only since I filled up my case with HDD's which hinder airflow.
CP5670
5,660
762
My cards idle at 43 and 44 on the stock CO coolers with 33% fan speed. There aren't any side fans or vents near them, although I have the PCI slot covers just beneath each card open to give the fans an intake, which helps the temperatures slightly.
