7600GT overclocks. HELP
SpeedZealot369
2,778
My bro has this card with a vf-700 on it, I was wondering how far can he push the card?
He has it at 610/800 right now. How much more can it take? What oc's have you guys gotten?
-SZ
lopri
13,310
687
You know you have to be careful with memory mod, right? I wouldn't touch Vdimm.
SpeedZealot369
2,778
Ok, I will only do a GPU mod then. All I need is a pencil :) sweet
How do I know exactly how much pencil to use? Like how much to shade?
Also is there a way to see the voltage without a multimeter?
-Josh
Edit
I did the pencil mod, now it doesn't matter where I clock the card riva tuner gives me an error. Same with overclocking through nvidia drivers. Help?
lopri
13,310
687
Umm.. you did it without a multimeter? I surely hope not..
But then again it usually takes alot of shading than many would make it out to be. It is also possible that graphite was touching nearby resistors. Erase it thoroughly, and final clean with rubbing alcohol. Get some sleep, and go to a hardware store tomorrow and get a multimeter before you attempt anything else!
SpeedZealot369
2,778
On the resistor, there is silver on the top and on the bottom. Do I need to shade those too?
-Josh
t73
78
In what extent will the 7600GT improves by this mod, will it reach similar performace of an 7900gs?
avi85
988
I won a 7600GT KO from evga last month and today they finally shipped it, so I decided what the hell and tried the pencil mod on my current 7600GT (eVGA, but not KO or CO, standard clocks and obviously binned cause the highest oc on the core was 590 at default volts).
At first I checked the resistance, it was 409, so I shaded some and then the resistance was 394 at that point I was able to reach 621 on the core so I shaded some more and lowered the resistance to 384 (which is about how low he says to go in the article) at which point I was able to reach a core speed of 638.
How crappy is that? How much can other people reach at ~385? How much have people lowered the resistance?
Lopri, what is your resistance at?
And last but not least, I was thinking of selling my new KO while still sealed and making probably $20 more than I would if I were to sell an unsealed one but if I could get a much better oc on the KO I'll definitely open it and sell my used one, so what would you guys do (on my current one the GPU oc's like crap but the RAM actually reaches 840 at default volts, how high should I expect the RAM to go on my new KO?)?
Sorry for the long message but if you managed to read through it, I really appreciate it ;)
avi85
988
If my calculations are correct you'd have to reach about 750MHz to equate a 450MHz 7900GS (and lot's of gs's go way beyond 450...)
SpeedZealot369
2,778
-Josh
lopri
13,310
687
I had a 7600 GT briefly so I can't remember exactly. Also I don't think I measured the resistance - I just looked up the voltages. I believe I gave ~0.1V over stock voltage for the core to achieve 700MHz. The thing with 7600 GT is that it doesn't take a 6-pin power connector so it gets all the power from motherboard, which can possibly stress the card's power circuitry when v-modding. It's another reason why I wouldn't recommend memory v-mod. If your board has any setting regarding power supply for the PEG (could be worded something like 'Slot Power', 'PCI-E Power', etc.) try selecting higher values than your current one. Make sure to plug all power connectors on the motherboard as well.
