No mention of 256b in XFX's manuals + specified peak memory bandwidth is the same as other 7600GTs.  Plus, RivaTuner is telling me it's only 128 bit.
Any other tests?
While I'm at it I may as well ask a few questions cause I'm having some problems
Problem:
Aquamark and 3DMark(01-06) scores seem lower than what they should be, in particular Aquamark and 3DMark01.  For example,
Aquamark: 52K (78K+)
3DMark01: 17K (22K+)
3DMark03: 11K (13K+)
3DMark05: 5.4K (6.0K+)
3DMark06: 2.8K (3.2K+)
To put it into perspective I?ve listed the actual scores next to the generally accepted performance (from other forums) of the 7600GT in parentheses.  To really put things into perspective, 52K is about what a 6600GT will get.
Solutions(?)
- Updated to 91.47 drivers
- Have also tried using 91.32 (driver CD)
- Checked that AA/AF were not enabled in CP (though I?ll be wanting to check this again)
- Udpated chipset drivers
- Monitored temps using RivaTuner.  Well within specs, so at least it?s not overheating.
- Will be trying the card on a fresh install of XP later tonight to see if it helps
Odd thing is there seems to be a performance increase while running Oblivion so I know that the card *should* be working.  However, I have yet to try other games, like Q4, as I?ve only just started testing it.  So, any suggestions?
Oops, forgot to mention system specs:
Opteron 146 @ 2.4GHz
2x 512 PC3200 @ 2-2-2-8
... not much else comes to mind that could be useful
