750ti cards with 6-pin - is it optional or required?
VirtualLarry
56,587
10,225
http://www.superbiiz.com/detail.php?name=ZT-750TI2O
Looking at that card, it has DVI-I, DVI-D, DP, and HDMI, and twin cooling fans. However, it also has a 6-pin. Seeing as how that it is not required on most 750ti cards, do you think the card would function (possibly at reduced clocks) without the 6-pin plugged in?
Or is there an unwritten rule that if a card has supplemental power connectors, that they MUST be plugged in, all of them?
I figure that perhaps some of the dual-fan 750ti models have 6-pins in case you want to OC.
KaRLiToS
1,918
11
If you are referring to the OC edition, it requires the 6 pin to be connected if I remember correctly.
(Sorry your link doesn't work for me)
Insert_Nickname
4,971
1,696
Yup. Usually failure to do so will result in the PC being unable to post. Though I've seen some cards start in a "low-power" mode, which needless to say has terrible performance.
EVGA makes 750TI's with DisplayPort that doesn't require 6-pin.
http://www.evga.com/Products/Product.aspx?pn=02G-P4-3751-KR
A quick look at the EVGA page revealed that their pre-OC'd 750TI FTW requires 85W to reach 1189/1268MHz, so that's properly why. :)
http://www.evga.com/Products/Product.aspx?pn=02G-P4-3757-KR
imaheadcase
3,850
7
My 780Ti will boot with one connected, but the second that anything uses 3d graphics it will shut off. Learned that because forgot to connect 2nd one when built PC. lol
