71.84 WHQL does not fix SLI Widescreen DVI issue
dworley
Tested the latest official 71.84 WHQL driver and it did not fix the "jittery" rolling screen issue when running HL2 and CS:S widescreen resolutions: 1680x1050 DVI or 1280x768 VGA with SLI.
Workaround is to select 1280x1024 or any other 4:3 resolution or run 1680x1050 in a window.
NOTE: The install was on a clean XP SP2 image that I use to test each new driver version as it is released with my Dell 2005FPW DVI and Sony 17" Widescreen VGA with (2) BFG 6800GT OC.
Also 71.84 still has the issue where games will hang when started after the PC has sat idle for some time and had been awakened from monitor shut off / standby.
This is just a thought, but have you considered that if your using the same XP image to test new drivers, could there be something not right with the image?
I have run into this in the past. Just a suggestion, but you should try a fresh full time consuming installation. I would if it was me anyways.
And, have you installed the latest Dell driver for your LCD screen?
Keys
I have seen numerous posts regarding this same issue from other users so I don't believe it is a problem with my install.
Here is a post from another user I found that details the problem better:
> I'm having a problem with using SLI at a resolution of 1680x1050
> (Widescreen LCD). When using that resolution that rendered frame (or
> part of a
> frame)
> between the two cards no longer line up when they are displayed to the
> screen. The offset between the two is only a few pixels, it can be
> just a little annoyance or make the game unplayable.
> So when SLI is running in Alternate Frame Rendering (AFR) mode it
> causes a horrible flicker on the screen and the game is unplayable. If
> I switch down to a lower resolustion like 1280x1024 the frames sync up
> and the flicker goes away.
> In Split Frame Rendering (SFR) mode the drive dynamically changes the
> amount of the frame each GPU renders. With the resolution back up at
> 1680x1050 the offset between the two parts of the frame can be seen as
> a horizontal line that craws up and down the screen. Not a show
> stopper but annoying none the less. Lower the resolution and the
> problem goes away.
> I'm not sure if the resolution or the aspect ratio that is causing the
> problem. I've tested with the current release drivers and the beta
> drivers from nvidia's site. I have also tried both DVI ports on the
> primary video card.
I read a post in another forum suggesting that this problem can be fixed by changing the timing values under the Advanced Timing settings of the Screen Resolutions & Refresh Rates driver tab. Have you already tried playing around with any of these settings?
