70mm fan coices?
GnomeCop
Doesn't look like many choices out there for 70mm fans, at least I can't find any besides TMD fans.
Are there any 70mm fans any of you recommend?
Non TMD? Are the TMD fans loud? I hear they may be kinda high pitched for some
SVC got the 80 to 70mm adapters back in stock so perhaps you would be better off doing that unless an 80mm just won't fit.
.bh.
You would be surprised how much back pressure one of those adapters can generate, so the smaller the reduction step the better. Hope the fan you chose can deal with it.
.bh.
