7" TouchScreen Monitor with Remote
It looks like a Lilliput screen. The resolution seems off but that company makes some funky little monitors. Here's the link to what I'm thinking of:
Linky
That's the coolest, cheapest one they have but here's another 7 models:
Linky2
Gaidin
Thanks, you rock!
I have been searching the web for that monitor elsewhere. I don't really want to have one shipped in from the UK when I buy something stateside.
I'm looking at the Logic Supply 7" touchscreen...not sure I understand the specs.
Video system: PAL/NTSC
2 Video inputs plus 1 Audio input
VGA input (USB interface)
So it's an PAL/NTSC screen but it has a VGA input? Also, I've never heard of VGA-over-USB before (wouldn't that require some sort of digital-to-analog conversion?)
Though the port is physically a USB port I do not think the data is actually usb. The monitor comes with a cable that ends in a male usbA and splits out into composite video and L/R audio inputs. There is another cable that is the VGA input that hooks into the one cable coming out the back of the monitor.
I've wanted one of these to play with for a while but, while affordable, I can't justify it...yet. 🙂
Check out this review to clear up any more confusion:
Link
Gaidin
Edit: If you install it in a car, please post pics. 🙂
I can't find the link of the guy that did install one in his Vanagon, but I found the pics that I downloaded off his site.
I will see if I can post them here or somewhere else in the next day or two.
