D
Deleted member 4644
I have an 8800GT sli set up. I need a new mobo, I would like to avoid 680i if possible.
I need SLI, but don't need insane overclocking.
Originally posted by: Deleted member 4644
Does 780 have the same BULL SH** memory controller burn out issue?
is 780 really the only option?
Is it so under SLI? (SLI bridge playing a role?) Asking this because when I tested a single HD 3850 on a Bad Axe 2 I saw meaningful performance loss when used in x8 configuration.Originally posted by: Gary Key
750i is an option, the latest 650i from ASRock is an option also. If you are not into heavy overclocking then I personally like the 650i/750i solutions better. By the way, even at dual x8 compared to dual x16 on the 680i/780i boards, your 8800GTs will be just as fast. PCIe 2.0 and dual x16 does not make a difference with the 8800GTs in SLI up to 1920x1200 resolutions.
