- Jan 8, 2011
- 10,734
- 3,454
- 136
I was at 3200mhz cas16 and needed 1.27 SA voltage to be stable. Someone suggested reducing the ram speed so I could lower the SA voltage. It never occurred to me to try that because its sort of blasphemous and sacrilege, but I tried it.
So far its running stable at only 1.1 SA voltage with ram at 3000mhz, cas 15, command rate 1. So the bandwidth and performance is basically the same as before due to lower cas settings, but for some reason it requires way less voltage to be stable.
I just thought it was very odd and totally unexpected for the chip to hate 3200mhz so much. At 3200mhz and around 1.1 SA voltage, it wouldn't even post. Also, It doesn't even care about the cas latency. It just hates those extra 200mhz. Is that unheard of for you guys too? Maybe you aren't surprised by it but I am. Crazy.
