6800gt vs X800 Pro
Well I play Counter-Strike, Counter-Strike Source, and Battlefield 2 so what woudl be the best decision.
Originally posted by: Dippy
how do you mod it?
well it depends...you cannot mod it to the XTPE if its in PCI-e express format. if its AGP its possible but it must support VIVO otherwise the mod will not work.
Check this link out
I suggest you try out the mod but you could damage your card or unlock damaged pipelines...and have a spare PCI card incase the mod fails so that you can reflash the bios of your damaged card.
