- May 6, 2004
- 440
- 0
- 0
Basically here is the problem. I took my computer somewhere to LAN on. Worked fine at the LAN. I come back to my dorm. I set everything up. I turn the computer on and everything looks funky... I can now only go at 640 x 480 (32 bit color max) or 800 x 600 but ONLY with 16 colors.
I tried reformating today. I unpartitioned everything and then with out making a partition just went to install windows. Windows reinstalled but I have the longgggest boot up time I have ever seen on a computer. Everything seemed fine until I installed the nvidia drivers and restarted...... Now it is back to like it was.
Ways I have worked around this is by disabling the card in the Device Manager and restarting. It works just fine then. I enable it back, it goes back to like it was.
System specs:
AMD 64 3000+ 939 socket
MSI Neo2 Platinum Mobo
480w Thermaltake PSU
80gb Seagate Harddrive
1gb of DDR memory
Also the computer was/is pretty dusty. Working on getting on top of that but I need to buy another screwdriver. I also haven't tried taking the card out and looking at it.
Think my video card is bad now?
Any help with this will greatly be appreciated.
System specs:
1gb of DDR memory
