Originally posted by: nippyjun
Farcry benchmark using benchemall:
Far Cry
Using Max settings.
Map: Fort Demo: BenchemallDefaultDemo
640x480 not selected
800x600 not selected
1024x768 not selected
1280x1024 not selected
1600x1200
run# 0: Average FPS: 48.33
TimeDemo Play Started , (Total Frames: 2737, Recorded Time: 51.59s)
!TimeDemo Run 0 Finished.
Play Time: 56.64s, Average FPS: 48.33
Min FPS: 38.33 at frame 1845, Max FPS: 60.71 at frame 1640
Average Tri/Sec: 6739721, Tri/Frame: 139461
Recorded/Played Tris ratio: 0.46
TimeDemo Play Ended, (1 Runs Performed)
yea, must be the cpu holding you back (or the messed up drivers).. when is nvidia's new wonderdrivers supposed to turn out? inq had em being released wed-thur of last week
Benchmark session result
Detailed info located here:
C:\Program Files\BenchemAll\result\2004.05.18.11.40.54.\
Far Cry
Using Max settings.
1024x768
run# 0: Average FPS: 56.28
1280x1024
run# 0: Average FPS: 57.45
1600x1200
run# 0: Average FPS: 54.02
Play Time: 50.67s, Average FPS: 54.02
Min FPS: 40.17 at frame 574, Max FPS: 65.23 at frame 913
Average Tri/Sec: 7772298, Tri/Frame: 143883
Recorded/Played Tris ratio: 0.45
edit
altho maybe the blame is solely on the drivers since your 3dm cpu score is better than mine?
http://service.futuremark.com/compare?2k3=2578353
let us know some updated results when the new driver is released as it's suppposed to improve far cry performance.
