660HW-T1 Connection to Cable Modem
mysgies
Hi ALL
Hi
I have just brought this product 660HW-T1 and was trying to install it.
I have broadband internet connection from NTL through cable modem which has a Ethernet cable as output to connect to internet. I like to connect it to the Zyxel router but I am not sure where I connect the output of Cable modem to the router as their doesn't seem to be any connection for this purpose.
I try to put the ethernet cable from Cable modem to Zyxel and another cable from Zyxel to PC for the configuration purpose but this doesn't seem to work as after saving the configuration from Genie, I am unable to connect to the internet and Wireless access is not active as well.
Can you please guide me to setup this device.
Thanx
It appears that the 660HW is a combination DSL modem/router, with no input for another internet connection besides the DSL connection. It doesn't appear as if you're going to be able use it as a router for your cable modem. It may be possible to turn off the routing features of it and just use it as a wireless access point, but not to use it as a router with your cable modem.
