6600GT OC... temp. advice !!
crazylegs
Hi all.... have just been OCing my Leadtek 6600GT using Coolbits....
got it up from:
Core - 500 >>> 579mhz
MEM - 1000 >>> 1090mhz
The temp after a few mins shoots up to and levels out at 73C (from 32C idle)...seems HOT to me even though the warning temp is set to 145C as default !!! Although at stock temp goes up to 69C...
Looking for any advice concerning temps for this GPU....
Thanks all
OK.... was probably more surprised that it was 69C at stock settings - only a 4C jump (5%) when OCed by 15%... but still would i be killing my GPU in like no time at all at 73+C ???
Hmm, don't panic, those temps are rather high, but not alarming... Try RTHDRIBL to cook it... 😉 It is more stressing than any game out there...
EDIT: However, an aftermarket cooler like the Arctic NV Silencers are always a good choice in case you don't really trust it...
my 6600GT gets up to 73d when im giving it a real beating and i have been using like this for months so i think it should be fine
As long as you are not running any voltage tweaks and have some form of cooling, the core will be unstable and crash your app/computer before it will do any damage.
Translation: As long as the heatsink is on it, don't worry about breaking it.
thanks loads for your help guys.... i'll have to re-clock the mofo now !!!!! love how quick n easy it is using Coolbits mod
Here are my 6600GT OC results (on a 20 degree (Farenheit) day with the window wide open and a fan blowing directly into the case with the side off and a zalman vf700cu)
615/1255
30C idle, 35C load
Here are my overclock results normal (with the zalman cooler)
585/1220
47C idle, 56C load.
I'd say your temps are a bit toasty, but not too high.
