Hi, I just recently set up a computer with a 65w AMD 4000+ Brisbane processor. I was under the impression these things were supposed to run pretty cool, however the thing is currently idling at 47C.
Now, I'll go ahead and mention that there are a lot of factors that could heat this thing up. It's using the stock heatsink and thermal grease, and is in a small case (3.5" high, 12" wide) with little clearance over the heatsink. I'm also in Florida.
However, right next to it is sitting a notoriously hot Socket A 2600+ (albeit in a full size case w/ Arctic Silver and a 3rd party heatsink) that idles in the low 40C's even on the hottest days.
I know the cooling setup isn't optimal, but should this thing be running this hot even under these conditions? It's for an HTPC so the idea is small and quiet, but the quiet part is hard when it's running this hot, I was hoping to be able to crank down the fan speed some.
So given those conditions, does this temp sound about right or could I have seated the heatsink incorrectly or something?
