64bit/66mhz IDE RAID Controller
Boonesmi
14,448
im looking for a 64bit/66mhz ide raid controller
what im wondering is who makes the best ones?
i know promise has the fasttrack100 tx2 and tx4, but they are software raid and only support 2 drives in RAID0
i would prefer something hardware based that can have 4 drives all stripped
i have looked at the 3Ware Escalade cards, for example the 7410 has been of interest, but from what i can gather its 64bit/33mhz and i dont know if it will run in my 64bit/66mhz pci slots...
anyone know if 64bit/33mhz cards run fine in 64bit/66mhz pci slots?
what other RAID cards should i look at??
bozo1
6,364
Only 66MHZ cards I've seen are some SCSI Raid, Gigabit Ethernet and Fibre Channel. No IDE.
Boonesmi
14,448
the promise fasttrack tx2 and tx4 are both 64bit/66mhz... but they arent hardware based raid.
and i belive i need hardware based raid if i want to run more then 2 drives in raid0, or if i want to run raid5
bozo1
6,364
Looks like the Fasttrack TX2000, Fastrack100 TX2 & TX4 are all 66MHz and allow up to 4 drives Raid 0. (I shudder at the thought - lose one drive, lose it all.) It will do 2 drives Raid 1 or 4 drives Raid 0+1.
staticfly
179
well.. 3ware cards are mostly 64bit, plus they can handle up to 8 ide drives. They are very impressive. Im not sure if they are 66mhz though. These are even raid 5 cards. What are you looking at using this for? 66mhz 64bit has a LOT of bandwidth.
Aug 16, 2001
30
The fasttrack100 tx2 and tx4 are not 64-bit, they are just 32-bit/66mhz. Look at their site, they don't say anything about them being 64-bit, they just say that they are 66mhz and if you look at the pictures you can see they are not 64-bit just 32-bit. I think if they were 64-bit they would cost at least $100 more. If I am wrong someone correct me.
edit: spelling
edit again: another spelling error
staticfly
179
they are only 66mhz not 66bit, you are correct. Plus they mention 200MB/s which is where the 66mhz comes in.
Boonesmi
14,448
you may be right about the promise cards not being 64bit
but i think the 200mb/s comes from the fact that its 2 channel ata100... cause 32bit 66mhz has 266mb/s of bandwidth (basically just the normal pci bandwidth of 133mb/s X2)
anyone know where to get a 3ware escalade 7450 or 7850 for a reasonable price?
i have several 30gb IBM 75gxp drives... i would like to run 5 or 6 of them in a raid5
