It's a 60v pack, 9 amp hours I think. The table saw runs a pair at a time producing 120 volts.
DeWalt's 20v MAX malarkey has always made shy away from their tools. The 20v number is a sham and it makes calculating Wh capacity harder than it needs to be.
Traditionally battery voltage has always been advertised at the cell's nominal voltage. A good example of this would be NiMH batteries. They are universally advertised as 1.2 volt batteries. In actuality the voltage of NiMH cells fluctuate greatly.
From my own personal experience I have seen voltage as high as 1.5v during the end of a charge cycle. I have seen fully charged resting voltage around 1.4v and a mid cycle resting voltage in the 1.3v range.
Lithium-ion batteries typically have a nominal voltage of 3.6 volts with some being advertised as 3.7 as well. For simplicity's sake lets just stick with the 3.6v number for now.
The small 20v MAX battery packs DeWalt sells contain five lithium-ion batteries in series. The larger packs contain additional groups of five networked together.
Given a nominal voltage of 3.6v/cell: 5 x 3.6v = 18 volts.
Lithium-ion batteries can be charged up to 4.2v/cell. A fully charged cell at rest will eventually settle
to 3.7-3.9 volts/cell.
So yes, a string of five lithium batteries at some point will give you 20v across the terminals.....but quoting 20v is pointless and pure marketing nonsense.
Lastly and the reason why I started to wright this is the first place. DeWalt's new battery packs are going to be 9AH at "20"(actually 18) volts
When the battery is configured to output "60" (54) volts capacity should drop to 3AH. The real metric to look at is watt-hour (Wh) capacity. Both ways you slice it, this is a mammoth 162 Wh battery.
