So since the stock fans in the 600T suck and not in a good way i was wondering what some of you may have done to beef up the front cooling of this case.
I recently replaced the top 200mm fan with 2 120mm 2100rpm yate loon fans and it dropped my CPU temp by 6-8c so obviously the stock fans are crap. The front doesnt seem like its going to be as easy to swap because there doesnt appear to be room for a standard 25mm fan, the stock 20mm fan just barely fits in there without hitting the drive cages. Also there doesnt appear to be enough room to fit 2 120mm fans ontop of each other anyways without hitting the 5.25" bays.
So what are some options people have been using with the front of this case? Im considering cutting a hole in the front fan filter to get that extra 5mm and fit in one fast 120mm fan that can move as much air as 2 slower 120mm's, Maybe a 4000rpm delta or something like that.
