you can allways buil one yourself, all you need is a funnel that is big enought and 2 aluminum squares, and a drill and saw...
it is quite easy, as long as you got a good saw and an old pan. Or what worked for me is an flat pice of mettel, that I put on the bbq to heat it up... then you put the funnel on there, when it is not too hot, you don't wanna melt too fast... well it is fairly easy, after that, you need some strong stuff to stick the aluminum plates on there,,, I would try that what surfers use to repair their boards... well or just look around in your wall mart or home depot...
That worked for me, I was about to put a 120 mm fan on there, but no way, the case is too small...
do it yourself... you can do it...!!! lol
it is a lot more fun, sounds like a redneck like I was told...
