6 to 8 pin for gtx 770 lightning?
Derik22
8
Hi guys so i will probably buy gtx 770 lightning but i have seasonic 620gm 620w which have one 6 pin and one 6+2 pin and for lightning i need 2x8 pin i know with lightning i will also have 6 to 8 pin adapters but how much is safe to use these adapters also my psu have two rails 2x24A and have i5 3570k @4.2ghz with 1.152v?
Thanks ;)
amenx
4,632
2,934
It should be OK. The ref 770 power draw is 230 watts and the lightning adds around 20 watts more to that according to reviews. So power from pci-e slot = 75w, max power from 8 pin connector = 150w, power from 6 pin connector = 75w, so should be covered.
amenx
4,632
2,934
Btw, as I recall the gtx480 had 6 pin + 8 pin connectors. And its TDP was 250w, about the same as your lightning.
