I got a 6 port baybus (XOXIDE) given to me for free along with 2 cheap case fans.. only problem I see thus far is that the case fans don't have the small 3 pin connectors that baybus does.. well.. they SORTA do. They have a single yellow wire attached to a 3 pin connector and then a normal sized 4 pin power connector(male and female to put inbetween other devices) .. I'm not quite sure if these work with the baybus, much less how it would work.. maybe I just need to cut and splice? Any help would be appreciated.
