6 pin firewire to usb2 cable
herkulease
topic says it all. Is a 6pin firewire to usb2 cable possible. I with the xbox 360 I'd love to be able to use my ipod while playing but its only usb2.
Yes I can afford to buy a new/use ipod that uses usb2 but that's defeats the purpose when the ipod I have works perfectly fine.
If such a thing exists and you knwo who sells one please link them.
Originally posted by: Tu13erhead
Uh, you could just get one of these. Not sure if the 360 supports it, though.
can you tell me what the item is. all I see is session timed out.
what the ipod has to do with the xbox 360 is that it can play music off of it. but the 360 only has usb2 ports.
Whoops. Try this instead.
EDIT: You can likely find one for a lot cheaper, I'm just providing a basic link.
ah thanks but those don't work for me. . I have a 2nd gen ipod that only supports firewire. I'll just continue using headphones while playing
I've heard that USB hubs work with the 360... Perhaps you could find one that has a firewire input? Most likely, it would have to not require drivers, though.
