ddbnbbbrsy
Hi all, we have a Dell T3610 workstation with a 685 watt power supply.
It has two 6 pin pcie connectors on it.
We're testing out an Asus Strix 980, but it requires a 6 pin and an 8 pin power connector..
I've read that per "spec" the 8 pins should supply 150 watts while a 6 pin is only 75 watts.
I've also read that nvidia reference spec for a 980 is only two 6 pin cables.
We are not doing any overclocking, but this system will be used for 3d / "workstation" type work 8 hours a day all week long.
Thoughts? I can't imagine that at stock speed it's pulling all THAT much past the nvidia reference 75 watts on that 8 pin connector. We're using all but one of the SATA power connectors, so I'm a little leery of converting a SATA power to a 6 pin connector.
Thanks
Thanks
