Task Force 6 LED Aluminum Flashlight It's showing $21.55 but after putting in my zip code it goes to $11.97. Since it's available for delivery I'm assuming it will be the same price everywhere. Was also available in store.
i dunno, at 20 dollars you can get atleast 1 watt led powered lights these days. cluster led was a stopgap before higher power leds came out
checkout flashlightreviews.com and candlepowerforums for more info🙂
it would be reasonably hot for maybe 8 bucks or less. 😉 i dunno to me anything above 10 dollars is a lot of money for a flashlight and then you might as well spend for a decent one.
