6 Fans?
imported_Ziggy
Would 6 8cm fans be noisey?The case is the
Aspire Blue Turbo Case Super Light Weight Heavy Duty Aluminum Server Case w/ 420W Power Supply and Side Panel Window, Model ATXA7AW-BL/420 - Retail.
from newegg.com.
Thanks.
Get some quiet NMB-brand or Panaflo fans. Not much airflow, but very little noise. I have some 21-db 22CFM NMB fans in my PC - from 3 feet away, you can't tell that they're on. Thing is, I have other fans than them - video, chipset, CPU (80mm, 41CFM), and 120mm intake - the CPU fan and 120mm intake are probably the main noise-producers. I still wouldn't call it a jet-engine though.
its not the number, but how loud each is really. get quiet fans and match with speed controller, and tune to please.
