$59.24 Altec Lansing ACS54 PowerPlay Plus 5-Piece Speaker System for Gamers
kingz
1,623
Is it just me or are there two versions of this speaker set. One has bass adjustment on the sub, the other doesnt.
javathehut
318
I have these speakers (4 not 5) and they rule. Clear audio quality and a great subwoofer. Typical Altec Lansing quality merchandise.
cheapbastich
Banned
Jan 7, 2001
141
unless you break one of the itty bitty pins on the power connector, and cant get it
replaced..............mine are just sitting here...........
freemanteo
1,996
This is'nt really hot for me,my local Sam's Club sells them for less than $50. The price stays that way but the product does'nt move much.
Just my 2cents. :)
drti
Banned
Mar 12, 2001
735
there is an $20 rebate floating somewhere for this item ACS54. i will try to find them and post it.
NotAClue
254
I just ordered mine for $17.17 delivered... I know Sam's Club can't do that. A week or so ago I signed up for Incoming, an HP e-newsletter and I received a $10 Amazon.com gift certificate. Well, I did this 5 times. Special thanks to Sigity for providing the deal with HP back then.
Sorry, just realized the $10 certificate deal expired.
kombatmud
446
kingz, there are indeed two different versions. One has a bass adjustment on the subwoofer, the other doesn't. I have the one that doesn't, and have been extremely happy with it (although when I found out there was a different version, I wanted that one, because at the time I needed a bass adjustment). I don't think there's a way to tell the difference until you open the box. These speakers sound great, and are well priced, making them an excellent deal.
w74656
380
nnnyyy, no ACS54s aren't digital
I got the ACS56, one (big) step above the ACS54, one its digital, but only for the front
The ACS54s are for those of you who are on a budget and is not a bass person, the 4" driver on the woofer just doesn't cut it when it gets moderately loud. I am a bass person, and ACS56 all the way!! By no means are the 54s crappy, but my boss has ACS33s and they have a 4" woofer, just doesn't shake the floor or give your parents heart pain like the 6.5" ones on ACS56s do.
