580w Power Supply Enough?
Shultzee
I just ordered a System from CyberPower but it hasn't been assembled. I'm starting to have second thoughts about my 580 power supply. would 580w be enough for this system? I bought a Radeon 4870 1gb card to go with this.
CAS: ($20 off Mail-in Rebate) Sigma Gaming Windstorm Mid-Tower 420W Case [-32] (Reflective Dragon Print)
CASUPGRADE: NONE
CS_FAN: Default case fans
CPU: Intel(R) Core(TM) i7-920 2.66 GHz 8M L3 Cache LGA1366
CD: (Special Price) LG 20X DVD+/-R/+/-RW + CD-R/RW DRIVE DUAL LAYER (BLACK COLOR)
CD2: NONE
FA_HDD: None
FLASHMEDIA: None
FREEBIE_CU1: FREE! CyberPower Multi-Purpose Carrying Briefcase ($19.99 Value)
FREEBIE_CU2: FREE! Cyberpower Unleash The Power T-Shirt ($19 Value)
FAN: Intel LGA1366 Certified CPU Fan & Heatsink
FREEBIE_RM: None
FLOPPY: NONE
FREEBIE_OS: FREE! (Microsoft(R) Flight Simulator X Deluxe) Game
HDD: Single Hard Drive (500GB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD)
HDD2: NONE
IEEE_CARD: NONE
KEYBOARD: Logitech Deluxe 250 USB Keyboard (Black Color)
MOUSE: XtremeGear Optical USB 3 Buttons Gaming Mouse
MODEM: NONE
MULTIVIEW: Non-SLI/CrossFireX Mode Supports Multiple Monitors
MONITOR: NONE
MONITOR2: NONE
MOTHERBOARD: GIGABYTE X58 GA-EX58-UD3R 2 WAY CROSSFIRE/SLI DDR3 [-20]
MEMORY: 3GB (1GBx3) PC1333 DDR3 PC3 10666 Triple Channel Memory [-35] (Corsair or Major Brand)
NETWORK: ONBOARD 10/100 NETWORK CARD
OS: Microsoft(R) Windows Vista(TM) Home Premium w/ Service Pack 1 [+104] (64-bit Edition)
PRINTER: None
PRINTER_CABLE: None
POWERSUPPLY: 580 Watts Power Supplies (SLI Ready Power Supply)
RUSH: NO; READY TO SHIP IN 5~10 BUSINESS DAYS
SOFT: Free 60 Days Microsoft(R) Office(R) 2007 (Words, Excel, Access, Power Point, Outlook + More) - Windows Vista(TM) Required
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: NONE
TEMP: NONE
TVRC: None
USB: Built-in USB 2.0 Ports
USBHD: NONE
VIDEOCAMERA: NONE
VIDEO: NONE [-135]
VIDEO2: NONE
VIDEO3: NONE
WNC: NONE
JaYp146
410
Depends on the quality of the power supply. The only PSU I can think of off the top of my head that's rated for 580w is a Hiper unit that would be sufficient in powering the HD4870.
ther00kie16
1,573
Yea, Hiper is all I can think of too. Should be fine but what are you using this for? If you are gaming, i7 with a single 4870 is kinda unbalanced unless you are just playing flight simulator, in which case the quad is much more important.
Shultzee
It's mostly for gaming, the cyberpower system is $900 with OS, and the hd4870 1gb was $190. I was thinking later I could just add another 4870 but a 580 power supply might no be able to handle that idk. So this system is unbalanced? for $1000 is there a better way?
Blain
You can't blindly be guided by pure wattage ratings when buying a power supply.
The "quality" of the unit is more important than any "advertised" wattage rating.
ther00kie16
1,573
I wouldn't trust anything less than that 650w corsair ($68 more than the 580w and $108 more than the base config).
So if you are not afraid of swapping components, just go with the base config and add a power supply yourself. You can get a much better one for $100, or even $40.
I recommend 750w for i7 + xfire. Try Corsair 750w ($80 after rebate @ buy.com)
If you want cheaper, you could check out these PSUs at newegg.
Anand's article showed 420W at load for qx9770 + 4870 cf but almost all of that would be on 12V rail so look for something that would support >400W on 12V rail. Hell, even Corsair 450W model shows max of 396W on 12V rail, but give it some headroom and go for the 750w from buy.com, especially seeing as cost difference is a mere $10. That $10 should buy a lot of peace of mind when you add components later on or apply a monster overclock to that i7.
Edit: by the way, here's the corsair 750w @ buy.com
and here's a $5 off $100 coupon but you'll have to add $0.01.
Shultzee
thanks, I'll probably go with 750w corsair, and tomorrow I'll call and upgrade to 6gb ddr3 memory.
