5700rpm on the CPU fan!!
mqz4
Hey guys,
I assembled a AMD Phenom II X2 550 BE rig last month, I've been getting really high cpu fans rpms, about 5200-5700 with the stock cooler. The cpu runs at 52°C on idle, and 56°C on full load. CnQ is set to default in the bios. The results are same even with the remaining cores unlocked. The fan makes a lot of noise and can be really annoying.
Any ideas or suggestions as to why it is happening and solutions.
Thanks.
mqz4
the bios readout, the full load temp that i took was after three hours of playin flight sim
Markfw
May 16, 2002
27,394
16,236
Thats not full load, thats idle. Temps can change very fast, so 10 seconds later( before the computer could boot) the temp can drop 30c. I would get an aftermarket cooler.
