5600ultra vs. 9500pro/9600pro
Sabredan
32
Hi guys,
I was considering getting a 9500pro or a 9600pro, but I'm being held back by the problems that a lot of ppl are having with these cards. So the 5600ultra becomes a choice... what could you tell me about this?
I'm also concerned about the fan noise of the fx series. Is the 5600u very loud?
Thanks!
Lonyo
21,938
There are 2 5600U's.
An older one running ((I *think*) at 275/275) 350/350 actually, and a revision 2 running 400/400 or something like that.
If you do go for a 5600U get the newer version if you can. No idea about fan noise.
There are quite a few people who are not having problems with the ATi cards.
You could get a 9500Pro and see if it will work, and if not send it back and get a 5600U. I think the 9500Pro should be a little faster than the 5600U.
I think: 9500Pro > 5600U > 9600Pro in terms of speed.
I might have been thinking of the original non-Ultra card then, my bad.
But the newer card is still clocked higher, just not as much.
Apr 17, 2003
37,622
An older one running (I *think*) at 275/275 and a revision 2 running 400/400 or something like that.
if you are planning on overclocking the performance is 9500pro=9600pro>5600U
dragonic
254
Actually the speeds were 350/350
Sabredan: I would suggest taking the 9500Pro
Dragontail
25
hmm, my friend was in the exact same position as you. however he stretched his buget and got a 9700NP. maybe if u put in the extra $/£?
stardust
1,282
is that 5600U on ur list overclocked? then again... i dun think many ppl would kno the damn results cuz i can't seem to find a rev2 of the 5600U
but trust Hexus in the mean time
*edit*
maybe u are saying 5600U rev1
Apr 17, 2003
37,622
*edit*
i havent seen much about the rev2 and OCing
squidman
643
WHO has problems with 9500?! Those guys that overclock it to 9700 Pro stats, or thos guys that overclock it to 9800 Pro stats? For real man, its a perfect card.
Sabredan
32
I've heard the following problems (no OCing):
- Card doesn't work at AGPx8
- Horizontal interferences on the SVGA output, although not the DVI
- Small halts due to conflicts witht the sound card
I know this may be a too concrete case, but it definetely makes one think :)
stardust
1,282
yep the card hogs alot of system and hardware resources so u can expect that sort of problem
i think some earlier nvidia cards also had that problem but with the FX, there have been non that i kno of.
Pete
4,953
[1)]- Card doesn't work at AGPx8
[2)]- Horizontal interferences on the SVGA output, although not the DVI
[3)]- Small halts due to conflicts witht the sound card
1) AGP 8x gains you virtually nothing over 4x or even 2x.
2) I've heard of that rippling at 12x10 @ 75Hz. It's not solved yet? Or has it been narrowed down to specific cards?
3) I haven't heard of this, but it sounds more like a MB/sound card driver problem than a graphics card driver one.
Based on the reviews I've seen, I'd suggest a $200 9700 or a $160 9600P. A 5600U at $200 isn't a good deal. But if you're worried about compatability, then I suppose you may want to take the price and performance hit. I wouldn't.
