550W PSU. EPS->ATX. Is 24-pin to 20-pin ADAPTER OK?
Brickster
Well, wouldn't you know it, I just bought a brand spankin' new Antec 550W "True550" PSU from NewEgg.
My dumb-arse doesn't see that it's labeled as EPS, which means it comes with a 24-pin mobo connector.
My new Gigabyte board accepts a 20-pin ATX model.
I have seen the 24-pin to 20-pin adapter, though my questions are:
1. Should I get the adapter, or return the PSU for one with the 20-pin connector?
2. Are there any problems with using this type of adapter? Any reasons why it would be ludicrous to use an adapter?
Thanks,
Originally posted by: Carbonadium4
adapter, some newer mobo uses 24 pin.. so better off..
see if you can find cheaper than 9 bucks.. i have one but i sorta need it.. else i would give it to u for free.
http://www.power-on.com/connectors-adapters.html
Thanks Carbonadium; good to know. I wasn't sure if there were any negative impacts of using an adapter from 24-pin to 20-pin.
Anyone have any other comments?
I think I will go the adapter route.
Thanks,
Nope, most of the 24pin psu comes with adapter.. so its not a crime.. just dont buy a cheaper one and get bad wiring or loose one.. u know some cheap one has bad quality
