50% of Websites Using WebAssembly Apply It for Malicious Purposes
amd6502
971
360
VirtualLarry
56,571
10,206
Uhm, WTF is "WebAssembly"? Assembly code for the web? Does it execute in some sort of virtual machine? Is this standard on any common web browser? Why have I never heard of this before???
(I used to code x86 16/32-bit ASM back in the 386 days, so I know a little bit about this. I don't expect that this Wasm would translate directly into native opcodes, right? It must execute in a virtual machine, ala JVM or something, right?)
Reactions: JimKiler
amd6502
971
360
WebAssembly is a very bad idea. But yes the originators and proponents say that it is very high performance so it should be a "good" replacement for java.
Can it be disabled?
That's actually a really good question. I don't think it's easy to disable it in firefox. Not sure about chrome either but my gues is it's difficult.
Some browsers like palemoon don't even support it so that's one way to avoid it. Older versions of FF like versions 50-something have wasm disabled by default but are also not supported/updated anymore.
If anybody can do some testing and research on this question that would be great to hear about. So far I'm at the googling stage (found https://github.com/stevespringett/disable-webassembly).
I've also searched the about:config for "wasm" and found a handful of options, none of which disable wasm .
JimKiler
3,561
206
So should we go back to using Flash, LOL?
