50 ft HDMI cable, what to look out for?
Jul 10, 2007
12,041
at a cable this length, is there anything i should look out for to ensure that a quality image/sound is produced?
i'm reading a lot of reviews on amazon, many having difficulty with 1080p, and it only working when using 1080i.
http://www.amazon.com/HDMI-Cable-50-...9070063&sr=8-1
^just one of the examples, other 50ft cable reviews have the same complaint about 1080p not working, just 1080i.
HeXen
7,835
38
without a signal booster, i can't imagine its quality could end up being very good.
I know other stuff like USB or esata requires a booster if longer than 6ft or so.....why so long? plan on having your BR player in your attic?
sivart
1,786
I have a 35ft HDMI running from my Blu-ray player to the projector (okay, from the receiver to the projector) and it works find without any problem. Can you go any shorter than 50ft?
CrimsonWolf
867
i suggest going with monoprice or blue jeans for a cable of that length
http://www.bluejeanscable.com/
both will cost more then amazon but the quality level will be higher, especially with BJC
Ditto on BJC for a cable that long. Their stuff is great. They don't guarantee it but they claim they've run 1080p up to 125 feet. At $135.50 it's not cheap but should be a good bet.
It is certified to the longest distances of any HDMI cable we know of--45 feet for Category 1 ("Standard" speed), 25 feet for Category 2 ("High speed". In actual usage, it ordinarily will work at distances far exceeding these--we have run 1080p video through a 125 foot Series-1 HDMI cable without any information loss, but results will vary depending on the capabilities of the sending and receiving circuits of the devices in use.
Modelworks
16,240
7
Really not a good idea to run HDMI 50ft. The protocol was never designed for those distances so if it works count yourself lucky. Besides the cable quality you have to account for the equipment on each end and how good they are at error correction. It will not be the same for everyone.
The main problem is impedance , not signal strength. Any signal sent over wire encounters impedance. If it isn't correct then you get reflections on the wire that are like waves where your signal arrives at the other end and bounces back along the same wire interfering with new signals. The longer the cable the worse it gets. Look for an HDMI equalizer, it works to keep the impedance matched and prevent the reflections.
It is sort of like running USB 15ft+ . I have done usb over 30ft with just spliced together cables and some devices worked fine, but some wouldn't.
If you get an equalizer then the best place for it is middle way of the connection. Using 2 x 25ft cables with the equalizer will work well.
Modelworks
16,240
7
ok, what if i drop it down to say, 35-40 ft.?
how much better is that going to be?
Can't really say because it is going to depend on the equipment. Most stuff is pretty much guaranteed to work at 25ft over that and you have to try it and see.
Chapbass
3,147
My 50 footer worked just fine as well. That is until the ends broke due to the gauge of the cable being super thick and putting all sorts of stress on the ends :\
wtb HDBaseT
Number1
7,881
549
wtb HDBaseT
I had the same problem with my 35 footer. I moved the computer a little bit and the HDMI connector came right off. My source replaced it free of charge.....
On topic, one would think that having the HDMI logo on a cable would guaranty a level of performance, ie support for 1080P and down at the very least.
Modelworks
16,240
7
That is assuming they are a legit HDMI manufacturer. There is a lot of HDMI products that are black market.
Thankfully HDMI is about to be replaced for long distance cables. HDBASET and adapters for it are in the FCC approval process. Then all you would need is a cat5 cable.
CubanlB
562
On lengths 50ft and above I have noticed that your source devices hdmi can be just as important as the quality of your cable. In personal experience 50ft cable + Yamaha RX-V363 = 1080p fail. Same 50ft cable with a Denon AVR-1910 worked just fine.
Equalizers can help if you are having a signaling problem, but they can also draw power from the 5v on the hdmi down to a point where the hdcp will not function, and I never recommend installing equalizers where it will be difficult to access them (like in a ceiling/wall).
Destiny
2,270
Since we are on the subject to look out for in an HDMI cable... I have been receiving conflicting facts regarding HDMI 1.4... my friend who works for an electronics company told me HDMI 1.4 is not recognized or certified by HDMI themselves and that it might be just a marketing gimic? He showed me a cease and desist order from HDMI themselves regarding HDMI 1.4...Can someone confirm this? Modelworks can you confirm this?
Number1
7,881
549
HDMI
Your friend is on something.
Homerboy
30,890
5,001
I picked up a 24G 35ft HDMI from monoprice.
The 1st one they delivered was bad.
Exchanged with monoprice (shipping on their dime) for a new cable. Works flawlessly. Carries video and audio from basement XBMC machine to TV in family room. I LOVE not having the device in the same room :)
Modelworks
16,240
7
1.4a is recognized but the problem is its still in a state of flux. They only released the certification test in march so anything made before then was not allowed to be marked at 1.4a. After march any device bearing the 1.4a labeling had 90 days to comply with the test or remove the 1.4a labeling.
It really made a mess of things because it takes 6-9 months for an electronics company to bring something like a dvd player to the production stage and another 3-4 months to actually ship it. Some of them gambled that what they had in production would pass the final testing and went ahead and started making product with the 1.4a labeling. So there could be products out there made in the early part of this year marked 1.4a but are not actually 1.4a compliant which is what the HDMI licensing was trying to prevent by sending out cease and desist orders. The consumer electronics market is so competitive that some companies couldn't wait and tried to get the jump on having 1.4a products before they were supposed to.
Number1
7,881
549
WOW! :ninja: ... I double checked and the letter from HDMI said no company is allowed to promote HDMI 1.4?... discombobulated :mad:
I know they are trying to move away from this numbering system and start describing cables ast to what they are capable of. For example, theyll sell you an HDMI cable with 3D capability and network connectivity. Much simpler for the consumers in theory.
vi edit
62,484
8,345
My projector is a Mitsubishi HC3800 and even at 25ft there's some intermittent synching issues. It's definitely not recommended to go longer than that with my particular device. As others have said, it's the source and display devices that will be the weak link at that long of a run.
